Thanks for the comments , I will keep at it.
Right a quick update on Mallory.
As things went reasonably well on practice day I had high hopes here. Seven group 4 bikes on the grid. As usual practice 1st things seemed all good. Nice and dry all seemed good with the motor. Down to a 16 tooth sprocket from the 17 I had in at croft. 1st race away into Gerrards , I like this corner all bikes going flat out ! basically a free for all for who's got the biggest balls for high speed mayhem. That's what it is round there for a couple of laps until you get split up a bit. I managed a fourth in group 4 and 11th overall. Not bad for around 38 bikes on the grid.
Braking into Edwina's I noticed was a little twitchy from the front end. When returning in mechanic Gaz noticed the front wheel had tipped over to the left in the forks st the top. Bike onto the bench and it was apparent the disc was hitting the antidive bracket under heavy braking. Front end strip , either a spring or a buffer was at fault. Seeming as though nobody in the paddock had any springs a bodge was needed. One of the bottom buffers was cut down and the other packed up to align the links.
This got me away for the weekend. But it was obvious there was a good 5mn in the springs. One side probably becoming a lot weaker than the other.
2nd race was wet. Bugger my Achilles heel. Getting away a good start I managed to get past Dan Lewis for a couple of laps. This had me in 3rd for a while. But a braking mistake , to late and Dan got past. This race I finished in 5th.
Bikes on the bench in the camp to give a once over on sat night ready for Sunday.
This resulted in me getting a fourth in the 2st race on Sunday. Very dry but clutch slip was my problem here. I just couldn't get near 3rd place. Bike into the bench and backing the clutch adjuster off I was hoping would cure my problem.
Race 4. Well away but 2nd lap in , clutch slipping become a big issue. My Lth needs an overhaul. I still managed a 4th place.
A good weekend finishing all 4 races but a few jobs to do to the GP. New gear selector , clutch overhaul. And fork rebuild.
But a great weekend.
