SIP Speedo
Re: SIP Speedo
Postby jonw » Thu Nov 06, 2014 3:52 pm
jonw
Re: SIP Speedo
Postby Eden » Thu Nov 06, 2014 6:57 pm
Norm wrote:Is there anything special you have to do when wiring it up with a Wassel conversion? I know about the resistor plug, but something else?
Btw, if you have the active version of the Koso sensor, you don't need a magnet - any bolt head or nut will work, you just need to tell the speedo how many nuts equal one wheel revolution.
just wire the rpm pickup to one of the yellows before it goes into the wassel,
re: the magnet, you don't need to but you can, I did because it was easier to get the sensor close to something (the magnet) with out having to worry too much about mount position.
Eden
Re: SIP Speedo
Postby Norm » Thu Nov 06, 2014 8:37 pm
Thanks, I'll try and fit mine this weekend if I can brave the cold. I've got plenty of magnets stuck to various parts of my toolbox, so one way or another, I should be OK!
Norm
Users browsing this forum: Bing [Bot], Google [Bot], Littlewheels and 10 guests
