Sad truth is that I don't have the time to work on the 245,I'll start probably in December,I hope
This period,I play with something different.
I also need to do some exotic modifications
Warkton Tornado No.1 wrote:
Each to their own, eh?
Post by Dimitrios_231 » Fri Oct 14, 2016 12:19 pm
Nice set up Gerry![]()
I feel you![]()
I have found that Amal MK1 carbs work crispier with a velocity stack,they breath much better.
If someone needs clean trouser legs![]()
there is a special threaded adaptor that allows for the use of a foam filter.
Post by LateAgain » Sat Oct 15, 2016 3:07 pm
Bit of progress on mine this week. Finally managed to arrange a time that was convenient for both of us (it's taken a year!) to pop over to Adam W's house armed with barrel, piston kit, reed valve and assorted packers to suss out port timings for my EBay unknown shortened to 94mm barrel. He has an empty case and 62/116 crank to hand, coupled with his 'little black book' and knowledge we set about it.
The upshot after a couple of hours tinkering with various combinations of packers and base gaskets, with no need for further Dremel work is...
62/116 crank
8.5 maybe 9mm base packer required. Dependant on building up on my Injun case.
Transfers 128'
Exhaust 185'
Inlet 200' power ported arc on skirt.
Piston crown is exposed at TDC by about a mil but were going to look at that when I build up on my cases. Maybe make that up with a gasket, or my preferred method would be to recess the head and then set the compression/squish etc.
Pretty chuffed so far that the barrel is very useable in its current state. Build pics to follow...
Users browsing this forum: No registered users and 8 guests
