simple wiring question
Postby jaybee » Mon Jun 03, 2024 1:49 pm
1963 s2 Li125
so i am building this scooter, no battery, no indicators and i am told that the closest wiring diagram in Sticky (3rd ed) is page 323. this seems to make sense.
i have loom with grey, green brown and black, then red and grey brake pedal. brown and white horn
so i have wired it as follows:
headset >> junction block >> loom
green killswitch>>block>>green loom
brown horn >>block>>brown loom
black speedo bulb>>block>>black loom
lightswitch:
white to horn
red/blue direct to headlight
orange to block >>brown (is brown the power feed?)
and headlight earth to somewhere? direct to earth or via the block?
so i have a spare grey loom wire (from footbrake?) on the block,
and i know soemthing has to be earthed on the control rod housing.
must be an easy fix right?
John
jaybee
Re: simple wiring question
Postby gp200ts1 » Mon Jun 03, 2024 2:39 pm
are you running points ignition or electronic? the black is the rear light feed.
gp200ts1
Postby jaybee » Mon Jun 03, 2024 4:30 pm
have just edited my orig post to clarify black loom wire is connected to speedo bulb.
its a kick start, and kill switch. (so that means points??) its the grey that i dont really get. i am told brown is the live feed.
jaybee
Postby gp200ts1 » Tue Jun 04, 2024 6:33 am
without having the manual in front of me i am running on foggy memories. the grey is what gives power to the brake light i think so on electronic set up it should have a jump over to the brown. the black should feed into the lighting system with 3 connections at the headset. one black wire that goes to the back light, 1 black that goes to the speedo and 1 black wire that gives power to the system when the lights are switched on.
does this look like your set up?
https://www.scooterhelp.com/electrics/w ... le.nba.pdf
gp200ts1
Postby jaybee » Sat Jun 08, 2024 12:39 pm
thanks gp200ts1 for getting back to me.
my diagram isnt exactly like that . p323 of Sticky ed 3. its less complex
ill post a video. i presume i can just add a link to my youtube library?
also, how do i get LCGB to ping me when someone responds to one of my posts?
jaybee
Users browsing this forum: dickie and 12 guests
