adjust the headlight
Postby kennystag » Mon Apr 27, 2015 8:23 am
Hi All,
I am fitting a new headlight bulb to my 1986 sil gp, can anybody please tell me how to adjust the headlight, when I took the glass and casing of, there was a wire with a connector, but I have no idea where it goes, can any body please help.
Stag
kennystag
Re: adjust the headlight
Postby grandpa » Mon Apr 27, 2015 12:12 pm
Hi Kennystag,
the headlamp pivots on two pins either side of headlamp unit.There is a spring clip on the top of unit and an adjusting screw with attached earth wire at the bottom.Screwing in or out the adjusting screw tilts the headlamp unit.Refer to Scooter restorations web site section 10 item 10_18 earth wire and screw and 10_19 top headlamp spring clip.If the pivot pins are too short use part of a pop rivet to extend it.The wire is an earth wire
Grandpa
PS are we going to see some pics of this machine did you buy it already restored or are you about to restore it?
grandpa
Postby kennystag » Mon Apr 27, 2015 12:30 pm
Grandpa thanks.
I bought it untouched, just about ready for the road. I will send some pics later, when I find out how to put them on the site.
Stag
kennystag
Postby kennystag » Mon Apr 27, 2015 12:40 pm
Grandpa,
Do you have the web site details for Scooter restorations, it would be appreciated.
Stag
kennystag
Postby kennystag » Mon Apr 27, 2015 12:51 pm
kennystag
Postby Andy_S » Mon Apr 27, 2015 12:58 pm
Here you go, just scroll down to items 10_18 & 10_19
http://www.scooterrestorations.com/lambretta/lambretta-wiring-lamps/?curPage=2
Andy_S
Postby kennystag » Mon Apr 27, 2015 1:14 pm
Hi Grampa
Pic of my gp has now been posted. I am trying to wire up my battery charger so I can test the lights. What wire do I connect it to on the junction box in the frame?
Stag
kennystag
Postby grandpa » Mon Apr 27, 2015 2:47 pm
Hi Kenny stag,
Scoot looks good.The brown and purple wires are joined in the junction box.connect +12volt to either brown or purple via AN INLINE FUSE if you don't have a fuse obtain some 5amp mains fuse wire and use a terminal block to connect fuse.The negative lead from battery charger onto clean metal frame..The fuse is there to protect your harness in case you short something out.When I made my harness I dispensed with the junction box and used a terminal block instead
This may help
Left to right Pos 1(brown)and 2 (purple) are joined by a copper wire link in the upper terminal with a red wire going to brake light.4and 5 (brown) lower are from stator 4 and 5, upper are yellow from wassell .Pos 6 is for ign only. Red wires are for indicators and alarm.A red wire also goes to Battery.All circuits are protected by inline fuses.
When you switch scooter off the ign switch shorts the geen wire going to the HT coil to ground (Frame ground)I prefer connector blocks as you can screw wires in nice and tight but purists may not agree.
Hope this is some help
Grandpa
grandpa
Postby kennystag » Mon Apr 27, 2015 3:52 pm
Thanks Grandpa,
Thanks for the info. Just a pity I did not think to use one of the connectors, as I ordered a new junction box.
Stag
kennystag
Postby kennystag » Mon Apr 27, 2015 7:32 pm
another pic of my gp
kennystag
Postby rossclark » Mon Apr 27, 2015 11:50 pm
Nice, looks very original.
Users browsing this forum: Google [Bot] and 11 guests
