ideal engine temp
Re: ideal engine temp
Postby Eden » Tue Oct 28, 2014 11:13 am
Drop is also an indication that you have bad fuel with low octane and your piston crown is being eaten away. If you have an egt too when this happens the egt will read high.
Eden
Postby peejay » Tue Oct 28, 2014 1:01 pm
thanks eden and piskie for your replies :D
Postby peejay » Tue Oct 28, 2014 6:23 pm
Eden wrote:the numbers ive quoted are with the sensor under the spark plug. You will probably see lower temps with it fitted to the fin.
the sensors supplied with the gauge are no good for the plug for my RT 225, i wasn't happy it was a good seal and all just a bit confined. at least where i have the temp prob now is very near the plug but at the same time out of the way to minimise damage to it, well that's my theory anyway.
what's a ball park figure for the difference in temp reading where i have it as opposed to under the plug?
Postby Eden » Wed Oct 29, 2014 9:33 am
Temps will be a bit lower and wont read as quickly but after using it for a while you will soon get to know whats normal and whats hot on your setup.
Eden
Postby peejay » Wed Oct 29, 2014 9:48 am
Eden wrote:Temps will be a bit lower and wont read as quickly but after using it for a while you will soon get to know whats normal and whats hot on your setup.
thanks Eden, i have noticed a "lag" in temp increase when put under load up hill, it's surprising the difference you can get, it gives me a much better understanding of what is actually going on :)
Postby piskie » Wed Oct 29, 2014 10:24 am
Once your happy pejay you can play thrash it get it hot blip the throttle see the change flip the choke on see the change it really help understand throttle positions xxx
piskie
Postby peejay » Wed Oct 29, 2014 10:28 am
piskie wrote:Once your happy pejay you can play thrash it get it hot blip the throttle see the change flip the choke on see the change it really help understand throttle positions xxx
me, thrash it, no never :D
Postby kalifornia » Mon May 30, 2016 10:32 am
I'm using a SIP speedo with the ring on top of my plug which is held down against the metal part by the HT cap (rubber NGK type with the rubber seal off a bakalite NGK type). Do you think this will be less accurate with more lag than under the plug? I'm getting much lower temperatures than you guys are stating, between 121F and 142F (49C to 61C).
kalifornia
Postby jonashford » Mon May 30, 2016 4:09 pm
Take that sip speedo and throw it in the bin, then buy a gammatech :D
jonashford
Postby kalifornia » Tue May 31, 2016 12:56 pm
Lol, thanks for that. I'd like one but don't want to spoil the look of my LiS. When they do one that fits the standard speedo hole then I'm all in.
kalifornia
Postby Rich Oswald » Tue May 31, 2016 2:17 pm
kalifornia wrote:Lol, thanks for that. I'd like one but don't want to spoil the look of my LiS. When they do one that fits the standard speedo hole then I'm all in.
Couldn't agree more. Love the concept but they just look so wrong,
Postby Eden » Wed Jun 01, 2016 11:20 pm
agreed
Eden
