neily03 wrote:Is there some sort of solution available for earlier series 3’s? The spring makes removing the rear rim a right pain...
Warkton Tornado No.1 wrote:neily03 wrote:Is there some sort of solution available for earlier series 3’s? The spring makes removing the rear rim a right pain...
I could be wrong, but thought the one piece S3 panel spring can effectively swing down like the GP's. Isn't there a top clip that can be rotated (if not too tight) to allow that to happen? Both panels need to be off or unclipped to allow the spring to rotate.
neily03 wrote:Warkton Tornado No.1 wrote:neily03 wrote:Is there some sort of solution available for earlier series 3’s? The spring makes removing the rear rim a right pain...
Unfortunately not, the top clip is welded in place so prevents the spring swinging down
shane BBoys wrote:Regarding the S2 panel hook try Jon Betts safe you eBay price
Users browsing this forum: Google [Bot], nastro azzurro and 17 guests
