Warkton Tornado No.1 wrote:Most people that are interested in the technical advances that may be available with such an old, odd two stroke design inherent with the Lambretta would always try & keep in mind reliability.
That has to be why some of you are giving consideration to being able to sacrifice ultimate power for reliability by being able to ‘richen up’ as exhaust/cylinder head temperatures reach the zone where it’s fair to say that the piston is likely to suffer.
I doubt many people (having read this far!) will disagree that ‘adding fuel’ is just one way of avoiding disaster. It may well be the best, but, for example, further retardation of the ignition, may be another.
What I’m striving to say, is that ideally any action taken should ideally be automatic. It should not rely on the rider keeping one eye on the temperature. It’s bad enough having one hand hovering over the clutch all the time!
I believe that with the Mychron range of Data-loggers, for example, that it is possible to actuate whatever you want when a certain pre-set temperature is reached. So an EGT probe reaching 700°C, say, might allow the Data-logger to operate whatever richening device you place your trust in.
Has anybody on this Forum used, or considered using, their electronic monitoring devices to do anything along these lines?
I am interested in this technology, but mine is biased toward the track, if ever I get back to it.
However, there are more pro-active rider/tuners on this Forum that I will gladly lend a Mychron III along with a choice of 12 volt solenoids if they wish to research & experiment the feasibility of an automatic ‘Fail safe’ set up. My preference would be that an EGT probe be utilised, properly mounted in the down pipe as I believe this to be the most re-active means of ascertaining temperature. I may even have an EGT probe suitable.
PM me if you want to consider this option.
Users browsing this forum: Google [Bot] and 10 guests
