Wassel and SIP speedo
Re: Wassel and SIP speedo
Postby Eden » Tue Aug 25, 2015 9:53 am
spud wrote:Eden,
Everything else works on the speedo, its just the rev counter that doesn't!
ride over some time Spud, ill have a look :)
Eden
Postby gp200ts1 » Mon Apr 25, 2016 4:25 pm
Is there anyway of switching the speedo off when the scoot isn't running? Worried that it will drain the battery if left for extended periods and also don't like the idea of parking it up with the speedo lit up all the time.
gp200ts1
Postby Eden » Mon Apr 25, 2016 4:40 pm
gp200ts1 wrote:Is there anyway of switching the speedo off when the scoot isn't running? Worried that it will drain the battery if left for extended periods and also don't like the idea of parking it up with the speedo lit up all the time.
Conect it to your lighting so its only on if your lights are on. Good practice to ride with your lights on all the time ;)
Eden
Postby Wack » Mon Apr 25, 2016 5:39 pm
If you're running a battery and want to turn the feed off Beedspeed sell an ignition switch that has an auxiliary feed out on the first( ign on) position.
Users browsing this forum: No registered users and 8 guests
