GT250 build
Re: GT250 build
Postby Eden » Sun Nov 30, 2014 1:52 am
Ye fran race for now...
stator is indian with a vespa pick up and low tension coil. work to the mag is to match it to the case transfer ports, the mag was from an LI150 so the cut out is much smaller than it needs to be to aid flow in to the left transfer.
Road test will be as soon as I get a new long engine bolt, ive used a long right hand engine mount but some how ive lost the fking long engine mount bar DOH :oops:
As soon as it arrives ill be out on it :)
Eden
Re: GT250 build
Postby Eden » Sat Dec 13, 2014 11:22 pm
Got to go out on it today for the first time, I've been waiting for the engine mount bolt to arrive.
25 miles of running in done :)
Eden
Re: GT250 build
Postby Digger » Sun Dec 14, 2014 8:36 am
Sounds good. 8-)
Digger
Re: GT250 build
Postby Captain Pugwash » Sun Dec 14, 2014 11:27 am
Sounds really good, in the video clip when it gets into the power in third you can really see it starts to move 8-)
Is that on the 4.4-1 gearing in top ?
Mark.
Captain Pugwash
Re: GT250 build
Postby Eden » Sun Dec 14, 2014 12:06 pm
4.7 Mark
I do plan to run it on longer gearing but wanted to get a comparison against both my GT230 and my Italian cast 250 which both also run 4.7.
it does pull well when it gets on pipe but as im running it in im trying to keep it under the power for a few 100 miles.. but its hard to resist giving it a fist full :lol:
it pulls 4.7 very easy under the power so im sure it will pull longer gearing, but again, as im normally 2 up with tons of luggage it might end up staying on 4.7, after all at 7k rpm on 4.7 its doing around 75 mph which is a quick enough cruising speed.
Eden
Re: GT250 build
Postby bike grim » Sun Dec 14, 2014 12:40 pm
I was going to comment that you were winding it on a bit the odd time considering you are running it in. Sounds great with that pipe on. Bet it's hard to resist. Also, I noticed you using the touchscreen on the Gamma with gloves on. How come that Doesn't work on my phone but they have Sussed it out. Makes a lot of sense obviously
Re: GT250 build
Postby Eden » Sun Dec 14, 2014 4:11 pm
The screen on the Gamma is the same kind of screen sat navs use, in that you have to press the screen not touch it.
Eden
Re: GT250 build
Postby Eden » Sun Dec 14, 2014 6:37 pm
Fuel economy is looking good on this tune, they normally use more fuel while running in! (45 MPG)
Video below shows the MPG during the first 35 miles, the jetting is set up very rich and its been running mostly well below the power so It looks like once its run in and running on the motorway in the power it wont use much fuel. One thing helping the MPG is that there is very little spit back from the carb mouth.
Eden
Re: GT250 build
Postby Eden » Sun Dec 14, 2014 11:59 pm
ridding in the city center is a good way of doing slow running in miles :)
ISC country
ye I know... I've watched it now and seen all the typos :oops:
Eden
Re: GT250 build
Postby stonerosesmod » Mon Dec 15, 2014 2:01 pm
Awesome video! That thing is pulling like a train.I bet giving it the full beans is very tempting at this stage? :D
stonerosesmod
Re: GT250 build
Postby Eden » Mon Dec 15, 2014 7:08 pm
stonerosesmod wrote:Awesome video! That thing is pulling like a train.I bet giving it the full beans is very tempting at this stage? :D
Yes its very hard to resist. at the very end of that clip I give it some in 2nd but bottle out at 7k rpm in 3rd. By 80 miles on the clock I've nipped up every previous engine I've run in so I must be behaving myself this time as its not even got close to tightening up on me, I'm sure I will nip it up sooner or later though.
So far running this motor in hasn't been a ball ache which is rare on a cast iron barrel.
Eden
Re: GT250 build
Postby bamrattle » Tue Dec 16, 2014 8:18 am
Hehehe Its all gonna end in misery. :ugeek:
bamrattle
Re: GT250 build
Postby stonerosesmod » Tue Dec 16, 2014 6:47 pm
Its a Lambretta! What could possibly go wrong?!! I do love watching these videos though,although these boring winter nights have me thinking of longstroke cranks and packer plates for my mugello...big carbs...porting.. oh dear!
stonerosesmod
Re: GT250 build
Postby Eden » Tue Dec 16, 2014 6:52 pm
if it all goes tits up I have no one else to blame but myself :?
And Trev, I know you want it going tits up so you can wave as you ride past me stuck at the side of the road you fka :lol:
Eden
Re: GT250 build
Postby bamrattle » Wed Dec 17, 2014 7:57 am
Eden wrote:if it all goes tits up I have no one else to blame but myself :?
:lol: :lol:
My turn nxt yr
bamrattle
Re: GT250 build
Postby rexton270s » Wed Dec 17, 2014 5:46 pm
it seams to have a nice power spead edan! :D
rexton270s
Re: GT250 build
Postby Eden » Wed Dec 17, 2014 5:56 pm
feels nice but cant really tell until its run in and I can ride it properly.
Went to work on it today..... its a great commuter :lol:
Eden
Re: GT250 build
Postby stonerosesmod » Wed Dec 17, 2014 7:23 pm
Much vibration?
stonerosesmod
Re: GT250 build
Postby Eden » Wed Dec 17, 2014 9:55 pm
stonerosesmod wrote:Much vibration?
a bit at a certain rpm, about 5k but its not excessive. at low rpm there is non and at high rpm there is non. at least ill know when the crank twists lol
Eden
Re: GT250 build
Postby Eden » Sun Mar 01, 2015 8:04 pm
I noticed some vibration on the GT250 today, crank may have twisted slightly but its not rubbing the stator away yet so fcuk it ill keep ridding it.
video with subtitles :)
Eden
Users browsing this forum: Google [Bot] and 6 guests
